Bluerdg
- Joined
- May 18, 2013
- Posts
- 29
- Reaction score
- 1
Pulled in about an hour ago and noticed I had a sound under the hood that sounded like a helicopter. Popped the hood and immediately noticed a slight wobble on the water pump pulley. Shut her down and took in the groceries. I had all the other cars blocked in the drive so I went out to move it for the anticipated water pump replacement and managed to just get it out of the way before the whole pulley sheared off the weld. Made a hell of a racket but got her shut off with the pulley and belt still in place. I've already been to Advance and back. Seems to be a pretty obvious job, going to replace water pump, thermostat, main drive belt, maybe the fan clutch and any hoses that don't look up to par. It's a 6L 2000 XL 2500 with tow pkg and trans. Any way of knowing which pump I need short of matching the old one. Advance has 2 options one with a 1.8" thermostat port and one with a 2+" port. Figuring it's the 2+ port option since it's got the trans cooler and all but figured I'd check it out.
