Transmission Sounds Lower RPM - UPDATE
gat0r
DFW
the TC have known issues. check w/ service mgr & see if they will work w/ you or cover the work.
or just get a stock replacement TC
some have mentioned you can use a Cadillac cts-V TC
otherwise, you could get circle D, Precision Industries, yank , Sonnax, Century trans, Jasper, gwatney perf, or mad dog trans for some info & see what works best for your budget & such.
gat0r
DFW
& your tune & tires would def. not be the issue ;)
my low profiles on 22s are almost 33" LOL
im over 65k mileage on my '15 , its supercharged w/ BBP tune.... & no issues to report.
Bighurk
Bighurk
Sounds good, out of all these brands, what do people prefer? Also was looking up the other night that different TC have diff Stall Speeds. What is the stock one and what is generally recommended?
lol
gat0r
DFW
from reading other forums...6l80e
stock stall is ~1600-1800
cts-V is ~1800-2000
no real need to veer away from stock stall speed, unless you are going inside motor to change cam, etc & will be chasing HP #'s / racing it
Bighurk
Bighurk
Okay thanks for your response!
Tiredmechanic23
Hey guys, I now have an update. As for the transmission, it came down to early signs of torque converter failure. All of the transmission gears appear to work fine when in manual mode when upshifting and downshifting. The difference between this and D mode, is that I let my foot off the gas for 2-3 seconds before pressing down again and this problem does not even exist.
I dropped off the truck at the dealership on stock tune and the problem isnt there that much but was still able to recreate it in the auto mode. The technician said that it is a problem with the torque converter and is not worth it to me to fix it if its minor because of the cost to take the transmission out and replace it with a new torque converter because of the cost to do it and that these transmission somewhere down the road will probably fail and would need to be rebuilt at some point and will cost more $$$ to fix it.
Now, my question is, what torque converter would be available to buy so I can do it myself because it problem bothers me and if left this way will eventually really wear down other components. So far, if I manually upshift and downshift wouldnt be an issue but prefer to fix it. But in the process, would like to get an upgraded torque converter. I have only found 2 available online and would like to see if you guys can give me some input which to get besides the stock ACDelco one.
Thanks!
I had my converter fail and had my entire trans rebuild as it put trash through everything. I currently run a 2k RPM stall converter from PATC. Its a 10 inch billet converter they hand build to order with 4 carbon fiber clutches. Its a beast as far as holding power goes and with the lower stall is street friendly. They also offer a free re stall if the stall you choose does not work for you.
Kimmly
