Torsion bars adjustments
Heldju
Hi
I’m trying to figure out how to sett the adjustment on the torsion bars on my 04 Tahoe. It soon going to get a front end alignment, but I want to have this adjusted correctly before it goes to the shop.
The problem I see is the front right corner sits higher then the left with about 3-4cm. Can I lower one side down to get it to sit leveled or do both of them need to be adjusted equally to function correctly?
Thanks for any reply
Helge
tom3
I'd have the front end guy level it. They probably see this quite a bit and it's not a big deal to them.
Byoung1330
Cookeville tn
both of them are not the same nor suppose to be. The driver side usually sits lower cuz the gas tank an stuff. Mine are not even an never have been. Just take a tape an measure. Then adjust. But after adjusting u have to drive it forward an backward a little hitting the brakes pretty good so it will settle back out. Also if u are adjusting the bolt up make sure the wheel is off the ground. Backing out on the bolt to lower I don’t Jack it up. Just when tightening the bolt
Byoung1330
Cookeville tn
Your alignment guy probably can’t adjust it out unless he takes it for a drive after every adjustment
DarkHearse
