domin8
Just Plinking
- Joined
- May 9, 2011
- Posts
- 6,038
- Reaction score
- 10
Since upgrading my tires to Nitto Terra Grapplers 305/50/20 I've noticed that my tires rub when they are turned at full lock. While working on my truck last Thursday to install a new radiator and engine oil cooler lines I noticed the sway bar was missing paint in 2 particular spots. Putting 2+2 I figured that was where the tires were rubbing. After doing a little research I came across some wheel spacers that fit the NNBS trucks. These are ¼” wheel spacers made by Dorman. The part number is 711-916. You will need 2 of these. Each kit only has 2 wheel spacers in it. They retail for about $25-30 each, so you'll be looking to spend up to $60. Dorman products are can be found at almost all auto parts stores, including Auto Zone, Advance, and O'Reillys. If they don't have them in the store tell them to order them. There are no fitment issues. There is plenty of thread on the factory lug studs to fit these with no issues at all. I even went for a test drive to make sure there weren't any issues these would create. I even tested them to make sure they did what I wanted them to do. I definitely don't have a rubbing problem anymore.
