TC shudder just started...
PA-WOODCHUCK
Flud was changed when purchased at 50K miles per TSB now at 95K. happens even in trailer tow mode. Does GM assist in repair? does additional damage occur if driven? Will another fluid change help? Please educate me?
BTW I have
2016 Yukon 6.2 and 8speed. I think TC just started to shudder, and how could I check this with Solus Edge(18.3 software). No faults yet... is there a way to record what TC/TCC is doing and how?
thanks
NickTransmissions
Sin City
The transmission bench
BTW I have
thanks
Look at the TCC efficiency, duty cycle and slip (rpms), specifically.
There's class action suits against GM on those things. Pull the trans and replace the converter - contact GM to see if there's a recall or warranty you could claim.
mics
Excuse my ignorance… How do you know it’s a TC shudder and not something else?
P
PA-WOODCHUCK
Dealer checked it, but going to have local trans shop pull pan and check. Both say there is newer fluid. shop road-tested vehicle. I'll update. Trans shop
Dealer also said fluid used in TSB only lasted for about 4 years, hence the newer version of fluid.
waterman
Sorry to hijack thread, are the tsb notices the responsibility of the dealer to inform the customer or is it the customers responsibility to see if there any tsb notices?
P
PA-WOODCHUCK
Not the best photo due to shop lights, but doesn't think it's self-destructing. Doing new filter, flush, newest fluid, friction modifier, then drive.
DB1337
