tahoe upgraded
houstone003
finally got enough cash to drop my tahoe and here it is....
did DJM 5" Drop Springs...
this is how it was after the springs installed only with out shock extenders..
here are the keys i used the STOCK key is on the right..
and this is how it sits now with the front keys, springs, and shock extenders ..
i want bigger tires if anybody is willing to trade? i have 235/60/17 and im looking for 70s 75s...
this is my crew that me & my brother are starting, nothing big or anything just us brothers and maybe some homeboys this is the sticker trying to come up with a better design but this is it for now...
spectre cold air intake for now...
AtomicHoe094
Atomichoe094
cleveland, OH
looks like your front chamber is pretty off. check into getting an alignment before killing the tires.. otherwise looks good
Tahoewhat
Ballin' on a Budget
TX
looks better dropped, but the tires look like low pros on there. and its a 60 series.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
even with shock extender in rear if you jack up the back of the truck if stock shocks are in there the springs will pop out.
DId you do the free travel mod in rear?
DJM rear hardware kit to relocate swaybars and trailing arms?
If you want the rear ride to get better down the road just hollar and btw just a heads up the tb belltech springs sit lower and ride much better thats why I dont carry the blue djm spring anymore.
H
houstone003
not to be a noob but whats the freed travel mod?
no i do plan to get the djm rear hardware kit and maybe in a month or to after i get the hardware kit im going to sell the springs and get the tb springs cause i want to go lower for sure so i will be in contact soon...
H
houstone003
Tired of this drop I want to go lower I want to shoot for a 5/7 how can I achieve this?.help?
Sent from my T-Mobile G2 using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Front djm 3 inch lower a arms
front belltech drop spindles
front djm shocks
rear djm hardware kit
rear belltech springs cut dead loops off
Rear Belltech shorter sp shocks
$1275 shipped
You can then add helper bags for 80 dollars in rear springs to lift it up when needed.
Also with the belltech coil due to it having like 4 dead loops you can cut them wihtout affecting ride.
H
houstone003
Whats the lowest you can go by cutting the dead coils?
waiteben84
