Sunroof drains
Dnrain
I have a 2002 denali that has rust behind the lower hinge of the front door and near the lower hinge of the rear door. Can this rust be coming from the sunroof drains? After painting the rust returned shortly after.
Miami-Dade
Super Moderator
@Dnrain Moved you here from 2021+section.
Welcome from Miami Beach!
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
Matthew Jeschke
Sahuarita, Arizona
There's a couple pieces of trim on the A-pillar. One is inside the door jam, adjacent the windshield (I don't have a photo). It's held on by two Philips screws. Remove it and inspect behind it. Next if you haven't already, remove the interior a pillar trim... That sunroof drain is a small rubber hose that runs down the inside of the pillar. You can see it in my photo where I rebuilt my dash... Make sure the hose isn't leaking or plugged.
Also post a picture of the affected area if you can so we can get a better idea.
Passenger side, in sunlight on pillar adjacent windshield.
montanaboy65
