Stock Height?
Skahide
I inherited a 98 Yukon 4WD. It was my grandparents so I'm not sure what has been done to it. It has running boards, and looks soooooo low to the ground. I plan on removing the running boards but im curious what the STOCK ride height is supposed to be. Im guessing ill measure from fender to center of wheel?
drakon543
center of wheel well to the ground also does it have the stock tire size on it. stock tire size for your model will be listed on the door tag i believe. sagging rear leafs or the torsion bars cranked down will lower the vehicle. also how many miles.
willxfs
My rig is a 1998 2door tahoe 4wd sport. I'm running 285/75/r16 tires which is one size up from the 265/75/r16 tires that the truck came with. My torsion bars are cranked just a little bit in order to level the truck. Height from ground level to bottom of the fender flares is about 37 inches and height from center of the wheel to bottom of the fender flares is about 22 inches. Hope this helps.
SDHanz
