Service airbag and steering wheel buttons
dthomas
Hello everyone,
I just picked up a 2003 Yukon. It has the service airbag message. Also the bottom buttons on the steering wheel arent working. None of the buttons light up. After reading on here I was sure it was the clockspring. I just replaced it today and no change.
I don't know if it is related but I think my bcm has a problem. If I program a key fob it will work perfectly until I lock the door with the lock button on the driver door. Once I do that the fob stops working. I have to pull the fuse and reprogram the fob.
Thanks,
David
D
dthomas
I may look into that later but the buttons arent functioning either.
aquacure
I found a guy who had the scanner to check air bag codes, mine ended up being the seat position sensor on the drivers side (wires were pulled out of the connector). I know you are trying to connect the steering wheel buttons with this problem but it could be separate.
D
dthomas
Good point.. I have just been assuming it is the airbag in the steering wheel giving me the problem.. I will go use a scanner that does airbag info and check..
Thanks,
David
joexyz98
as long as they work id leave um along they are a pain in the ass to change
513Tahoe
