fife2001
Okay, so on my 2009 Yukon Denali I have the Autoride suspension. I have had the 'Service Suspension System' light for a couple weeks. I inspected the system as I learned from another thread. I noticed the front right strut was leaking pretty bad. So today I replaced both front struts. (Still need to get alignment)
So I have not heard the pump since the light started turning on. But when it did run it was short and not very loud. I have thought to this point that, the system was saving itself since it detected a problem?
I have looked for the fuse that controls the pump, but I have not found it. All the other forums seem to refer to 00-06 Denalis and the RTD fuse. Should my fuse be labeled RTD as well?
So what should I do next? All the connections look good. Do I need the dealer to reset the system or do they need to run a diagnostics test?
