Redneck front locker
kirstinemichael
I heard a rumor that I could kick the front Axel on my 97 Tahoe, by drilling through a peice in the diff and buying an extended actuator pin that will reach through one side to the other. Anybody know about or tried it?
Jerky Arm Ape
North East Louisiana
I believe he is trying to say that...
You can connect the two axles together?
Or he is referring to the full time 4wd deal, I have heard about it but have never seen it in person.
It's basically a solid piece of metal that replaces the actuator and causes the differential to stay engaged permantley or until you remove the "pin"
Gzes
the drifting 2dr
Wichita tx
No I believe he means a locker but you drill a hole and slap a pin. Not sure how it works but he is thinking of a locker
ezdaar
Chat Troll
Redneck central, Aka Houston
Go do it OP! come back and tell us how long it took to break a axle!
Especially on the ****** lil twigs in your frot drivetrain.
I seriously hope this is a go fast in a straight line, mudbog toy.
Evem then, there's a reason the air and electric locker was invented.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i can tell you now that full-time 4wd ain't happening here. as for the actuator he could just wire it to be engaged anytime the ignition is on or he could spend $130 on a metal slug already designed to do it with out electricity.
Jerky Arm Ape
Um yeah.
That was theory #1.
A pin that would connect the two axles together for a posi-trac apparatus.
I didn't say locker because well that wouldn't be a locker.
Though If he is talking about a locker, some has thrown him one from the far left field.
Someone that doesn't know how a differential carrier works/ is made.
---------- Post added at 09:16 AM ---------- Previous post was at 09:11 AM ----------
"Buying an Extended actuator pin" made this metal slug come to mind.
But it doesn't go along with "drilling through a peice in the diff" & "reach through one side to the other"
SunlitComet
OBS Jedi-Do Good
technically an air locker turned on from standing still can happen and help but because of case material of axle assembly you will have to avoid shocks from the traction. so if you crawl very slowly from say mud or water you would probably be fine but any harsher then it may start to fall apart on you fast or slow like. just depends on how much you stress it.
rick9667
