Rear Entertainment 2018 RST
zrlee
Need some help with adding Apple TV to the rear entertainment system. Ive just purchased a 2018 RST and I’ve hooked up the Apple TV to the rear entertainment. When I turn the car on the power outlet in the back turns green and then goes right back off. It will stay off for a few seconds and come back on for a few seconds. Eventually it will go off and never come back. I have found out that if the the hdmi is plugged in it will never power on but if I plug the Apple TV in and let it completely power up I can then plug the hdmi in and it’ll work fine. I just want to leave everything hooked up all the time and hot have to unhook the hdmi before powering up every time. Anyone else experiencing this? I’m coming from a 17’ tahoe premier and it worked fine. Not sure why the 18’ would be any different.
TechSupport
I have my ATV hardwired in. The 4th gen uses a 110v ac to step down 12dc transformer. I disconnected the transformer and connected to a 12v source in the center console. I also added a switch. Yes I voided the warranty on the ATV but it works and I never have to unplug it. There’s plenty of room to hide it in the console when you take that back cover off.
Mac 2018 Tahoe
Where did you connect it at? can i get some pics as i would love to do this.
TechSupport
I fix it has a video of them breaking down a 4th gen ATV. The 12V outlets are switched on and in your center console. Tap off of one. I also added a toggle switch somits not always on. On the Cadi the back of the center console comes off by lifting up and out with some force. I have the ATV hidden away in there, the remote works fine. Airplay works. I used the NavTool box to add an HDMI port since my 16' didn't have one.
