Rear Door locks and window switches
roosh725
So I opened up my rear door panels and connected the handles. All good there. But does anyone know how to make the window switches work? All electrical seems to be connected including the harness to the switch.
Solace
NJ
Might need to be taken to a dealer and have it activated in the computer, same if you have autoheadlight/DRL delete.
JGaylord
I've an 09 PPV, took the switches apart they are missing a pad that actually presses on the electrical part. Only way to actually fix it is to replace the switches from what I've seen
iLikeEggs
Potato!
Oregon, USA
Yes, they are dummy switches. The cable and connector should still be there behind the door panel. I got my switches off ebay. Easy to install. Basically plug and play. No dealer programming needed.
preinternet
