Rear climate control problem
Mp619
Northern Virginia
I have a 13 yukon slt and the rear air (ac, heat, just air period) will not work. The rear climate control is powered and working but i get no air blowing out of the rear vents. I disconnected the pos and neg battery terminals (for about 10 mins), checked one fuse under the dash and one under the hood and everything is good. Started the engine made sure the front climate control was on AUTO with the rear activated and waited for a few minutes, NO LUCK. Hopefully you more experienced owners can spread some Wisdom. Help me out guys, thanks
kbuskill
NE. FL.
Bump
Sounds like the rear blower motor may have gone out.
Pull the panel in the passenger side rear and check the plug to the blower motor for power.
