Rear camber issue
Turki
Hello, I have a negative rear camber
camber on one side of rear axle (the rear right wheel at the top).
I attached some pictures here.
Any idea to solve this please ?
rear left (no problem)
rear right (negative camber)
OR VietVet
Multnomah Falls
Military
Willamette Valley
Welcome to the forum from Oregon.
How about sharing the year, make and model.
Since you do not have rear independent suspension I can only assume you may have hit something and bent to where the wear is being caused. You may also have a bad bearing or bent axle hub but since the axle hub spins, you should feel a wobble at the same time. You need to get the rig on an alignment rack and get a printout of the OE specs and what the readings are at this time. It could be a tire problem and not the suspension. Is this a tire that recently was rotated to the rear? Maybe problem is at the front if that is the case.
T
Turki
Thank you! , I appreciate your welcome and reply, I did rotate but the problem was before that.
The car is Yukon XL SLE 2017.
Bill 1960
Testing the Limits
If it wobbles as it rotates it can be a bent wheel or a bent axle shaft.
If it doesn’t wobble and the camber is off you have a bent axle housing.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Did you hit a curb or did anyone else driving it hit a curb or a large pot hole? Again, an alignment readout will help decide what is wrong and what to look for.
brittyboop0510
