Maximus1
- Joined
- Mar 6, 2017
- Posts
- 241
- Reaction score
- 108
I have an 04 Tahoe 5.3L Flex fuel. All header tubes read about 400 degrees except for number 6 which is only about 280. I clearly have a misfire. Checked compression and it's at about 150psi. Swapped coils with another cylinder with no results. Swapped injectors with no results. Any idea on what it might be. I just swapped heads to the 799 heads and then the misfire started. Also I did the screwdriver to ear test on the 6 injector and I can hear it pulsing. Getting a Too rich code and too lean code along with airflow out of range
