re gearing question
Fishin757
VA Beach
ok so i have a 98 tahoe with a G80 and 3.42. my main question is what gears do you change when re gearing? i dont plan on doing it my self at all but i would like to know how it works. also what would the best gearing be? i want to run 35s or 37 at some point but now i have 33s. i was thinking 4.88
retorq
Kingman AZ
You change the ring and pinion gears.
http://sierrabronco.com/TireGearRatio.htm
You can use that chart, find your RPMs with the stock tire/gearing, then find the new tire size and move over till you his a green number close to the first number you found. Then look at the top and it'll tel you what gears you need to run to keep the stock feel.
bowtiefreak
No Quarter
Near Philly
35 - 4.56 gears
37 - 4.88 gears
I run 35s and wish I had 4.88, I run 4.56. The change is rather minimal but I'm left wanting more on the suburban
Fishin757
Fishin757
VA Beach
i was thinking the 4.88. i have 33s now and will for another 4-5 years (maybe). Sunlit, i cant look at that... it just hurts. i was looking at the chart in on the sticky
Fishin757
Fishin757
VA Beach
actually now that i look at it its not all that confusing. i looked at it at about midnight last night when i was out of it :sleepy10:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i think it is a great tool once someone understands it.
---------- Post added at 07:05 PM ---------- Previous post was at 07:02 PM ----------
don't think it incorporates the gear venders unit preset numbers wise but you can still enter them manually.
Fishin757
Fishin757
VA Beach
So the way I have it now with 33s and 3.42 gears will that hurt my gas mileage? Because I use about 1/4 tank or just a little less than that a day
TheTahoe
