Random jerk in motor
Dneel81
OKC
So I swapped out the 4L60E for an NV4500. I paid little attention to the wires up under all the crap in the tranny tunnel. Went from button shift to manual shift transfer case..drilled holes in the metal on the floor hump...those wires up under there rode next to the screws and shorted out the pink wire engine fuse #1 I believe in the in cab fuse panel. It ran fine but would hiccup like you're describing. I had codes however. Are your fuses all working? I had several codes for MAF, AIT sensor, etc....all things that were powered off that stupid engine#1 fused pink wire that i shorted out from below. If all your fuses are fine and dandy, I'm probably of no use to you.
On3honksgo
I did just put in a new stage 2 trans from monster and have noticed it since then. I'm gonna check it out. Around town it runs and drives fine and dandy, has plenty of ass. I just more annoing than anything. I just wanna fix it.
Dneel81
OKC
I found mine the old fashioned way with a test light . PITA but it works. Again, If you're not throwing codes and all fuses are good, it's likely not the issue.
On3honksgo
It's throwing 3 codes p1057 p0160 and p0161. All from B2S2. Only notice it at steady cruising speeds in OD it does it
On3honksgo
I installed the new style spider injectors and upper intake gasket on my 98 and it fixed it for me
Pepper1700
