Radio turns off, then back on randomly
ylekiot86
2008 Tahoe, factory Bose system with Nav. The radio will randomly turn off, then back on. There have been a few times this happens, and the cluster will guit and come back on at the same time, this will also trigger the traction control light, with a slight shutter when driving. This all happens with in a few seconds, then everything is fine. Any ideas?
start by checking your battery connections, remove the cables and look for any corrosion, wire brush them and re tighten.
that's always the 1st place to start when there are electrical problems, check any other grounds you can find also.
you might also look at the "mega fuse" if your 2008 has it on the firewall? those have been known to get some build up on the contacts and cause problems.
they made changes to the battery connections over the years my 12 has it right near the post but I know on previous years it was placed on the firewall passenger side.
Y
ylekiot86
Thanks, I will take a look!
Pepper1700
