power steering pump weeping - 96
domer94
northwest NJ
was under the rig to swap out an O2 sensor and looked around. noticed a drop of what seemed to be like fairly new fluid on the bottom aft end of the pump as well as the whole bottom somewhat wet. nothng on the driveway. would this most likely be a line going into the back of the pump?
oh , and how do i tell if i have hydrobost?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
wipe it all clean and check it again later. unless you are diesel you likely don't have hb unless someone else converted it. hb has three fluid lines from the booster tied to the power steering system.
Off Road Pedia
