Power seat won't move forward or back
ChevyFreak
New York
Thx for the help guys. Anyone know exactly where the power pedal switch is. I found it and never used it but now I need it and can't remember where. No manual either.
sent from my thunderbolt
It should be one of the square buttons along the bottom, just under the climate controls.
T
thirsty1258
Does anyone know if I can swap a motor from the passenger seat to the driver seat to get it to move forward and back.
Sent from my Galaxy Nexus using Tapatalk
07lt
Try unplugging the main connector,then plug it back in.Sometimes the brain box under the seat gets jammed.It has worked for me in my other gm trucks.
T
thirsty1258
Thx will give it a go
sanch
What was outcome
Thirsty -
What was the outcome with this - I am having same problem with seat not moving up and down -
At 6'3" it is set for my wife who is 5'6" and I can't get it to lower.
I am trying to avoid the $300 seat controller motor and installation.
Love to know what you found out.
Thanks
-Steve
wardo
My passenger seat won't tillt forward. Everything else works.
tyriqdre
Does any one know how to manually get my seat to go back on 2006 tahoe
I've have the same problem with my driver seats, and it does not move at all... What i learned if you take off the back panel of the seat an unplug and replug the purple wire harnest it will start to work again... I hope this helps you guys also
capitalheel
Evening everyone, newbie here. Have a 2001 Tahoe LT with power/heated/lumbar seats. Lo and behold, my 5'2" wife moved the seat all the way up and of course it's now stuck. I'm 6'1" so would love some help. Similar issue to others except the lumbar piece works, yet none of the power seat features work (tilt, up/down, forward/back). Any tips? I had my local mechanic diagnose but the main issue about replacing anything is that the front bolts are blocked by the seat - thus can't take the seat out easily or get to the control module or motor. Good times.
Pepper1700
