Match number below with diagram. By doing C212 first you can disabble about evereything except the cigar lighter and liftgate hatch(if installed) at once from your fused supply wire.
CONNECTORS LOCATION
C100 LH rear of Engine Compartment at Bulkhead
C101 LH rear of Engine Compartment near Fuse Relay Center
C102 LH rear of Engine Compartment near Fuse Relay Center, Mounted on Fender
C103 LH rear of Engine Compartment, under Brake Master Cylinder
C104 LH rear of Engine Compartment, under Brake Master Cylinder
C105 (VIN J) Rear of Intake Manifold, near Center
C106 Top of Engine near LH Valve Cover
C107 LH front side of Transmission
C108 (VIN J) RH side Intake Manifold, near Throttle Body
C110 LH rear of Engine Compartment, near C100
C111 LH rear of Engine Compartment, below Master Cylinder
C114 At Convenience Center
C116 LH front of vehicle, near Core Support
C120 Rear of Engine, near Transmission
C200 Behind RH portion of I/P, near Heater Motor, in Foam Wrap
C202 Under Steering Column
C203 Behind RH portion of I/P, near Heater Motor, in Foam Wrap
C204 Behind RH portion of I/P
C205 At Convenience Center
C206 Inside LH "A" Pillar, lower portion
C207 Inside LH "A" Pillar, lower portion
C208 Inside LH "A" Pillar, lower portion
C209 Inside LH "A" Pillar, lower portion
C210 At Convenience Center
C211 Under Driver's Seat
C212 Under Driver's Seat
C213 Inside RH "A" Pillar, lower portion
C214 Inside RH "A" Pillar, lower portion
C215 Inside RH "A" Pillar, lower portion
C218 At Convenience Center
C219 At Convenience Center
C220 At Convenience Center
C221 At Convenience Center
C222 At Convenience Center
C224 LH rear of Engine Compartment, under Brake Master Cylinder
C225 LH rear of Engine Compartment, under Brake Master Cylinder
C227 Under LH side of LP, near Stoplamp Switch
C230 Behind RH side of LP, above HVAC Evaporator Housing
C240 In cross body harness, 100 cm into Seat Belt Switch Breakout
C241 Seat jumper harness under LH Front Seat
C266 LH side of Steering Column, near Bulkhead
C298 Behind LH side of I/P, near Convenience Center
C299 Behind RH side of I/P, above HVAC Evaporator Housing
C300 In Overhead Console
C301 LH front Kick Panel
C302 LH front Kick Panel
C304 Under Driver's Seat
C305 In Headliner at #1 Roof Bow
C306 Under front Seat
C400 RH rear of vehicle, above Auxiliary Blower Motor
C401 RH rear of vehicle, above Auxiliary Blower Motor
C402 Top center rear of vehicle
C403 LH "D" Pillar, top
C404 LH "D" Pillar, top
C405 RH "D" Pillar, top
C406 RH "D" Pillar, top
C407 Beneath LH rear Edge of Bed
C408 (03, S3) Beneath center rear Edge of Bed
C408 (06, 16) Lower center outside portion of Endgate
C409 Beneath rear center of Bed, near Bumper
C410 Top center rear of vehicle
C411 LH rear of Cab
C413 LH rear of Cab
C414 In line to front Dome Lamp
C415 In line to rear Dome Lamp
C496 RH "B" Pillar
C497 RH "B" Pillar
C498 LH "B" Pillar
C499 LH "B" Pillar
