It was pointed out to me that I posted this question in the wrong section (2015+) so I should try it here
I recently purchased a 2004 Tahoe and I really like it but the airbag light is on in the cluster. I have a Tech-2 so I hooked it up and found the B0092 code was present.
That pointed me to the passenger presence system so I checked that and the test flashed the code "65", but I am having trouble figuring out what the DTC 65 is calling attention to in the PPS.
After reading about the common harness failure do to pinching I removed the seat to inspect the harnesses, they were all good but the bladder in the
passenger seat is leaking.
Before I invest a small fortune in a new seat cushion, bladder, pressure sensor and module I thought I would see if anyone knows what that 65 flash code means or even better whether I can convert the system over to the other style manual on/off switch (like I have in my 2004 Sonoma) and get rid of the passenger presence system altogether
Thank you for looking!
