pair of shiney valve covers
blue99tahoe24
blue99tahoe24
bout that tahoe life
joliet il
aw ok hope u have better luck with the truck bro i was thinking about going with some msd things myself what do u think is good to start with?
---------- Post added at 11:20 PM ---------- Previous post was at 11:19 PM ----------
yea i noticed that his alt is on the otherside
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Coil, cap/rotor, igntion box/harness/plugs at same time, wires. In that order if short on cash. If not all will cost you less then $500 from amazon to do all at once. More details?
AtomicHoe094
Atomichoe094
cleveland, OH
i have in msd stuff
coil-40
cap and rotor- 20
wires-80
6a box was 55bucks
harness 20
plugs were like 18 or something..
ebay and forums are good for that type of stuff. cheap.
i also have the taylor wire protectors which was 60bucks.
SunlitComet
OBS Jedi-Do Good
FOR THE VORTEC L31:
Ignition:
6425
Coil:
8231
Spark Plug Wire Set:
32169
Harness:
8877
Cap/rotor:
8017
http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/Ignitions1/6425.pdf
Page 12 bottom half for hook up.
Change plugs to Autolite 605 copper cores set at .055 to .060. That is correct no platinum any more and check cap and plugs every year.
Most people mount the Control box in place of the under-hood reel light.
Note that they have a whole distributor if you just happen to need a new one but most don't. $220
Also note Box 6425 is the new one that has the one big connector plug in, diagnostic light and a programmable rev limiter.
Taking a breather for a sec.
---------- Post added at 09:49 PM ---------- Previous post was at 09:45 PM ----------
Damn I NEED A FREAKING JOB BAD. Must buy toys. BADLY.
retorq
Kingman AZ
i bought some nice crinklecut black valve covers for my truck.
http://www.jegs.com/i/Proform/778/141-131/10002/-1
And what does baffles have anything to do with racing? just keeps the oil off the PCV filter which is critical in the "blow by" system.
Most the of the "racing" covers don't have holes or the holes are unbaffled, you don't want to be sucking oil out of the block, just air.
felskee
Mmmmm Another reason I love my 95. I don't even have to remove my plug wires. LOL
Now this I find hard to believe ...
only cause you have to remove the whole ac bracket
Low Beam
