P0307 and stability track errors are back…
my plugs and wires have ~20k on them.
Also getting the attached p0899 error
I thought I had it fixed when I pulled 7 and gapped it last time….The misfire will disable the Stability system. Fix the misfire and Stability warning will be gone as well.
What is question on 40k?40K on them ??
change plugs - don't "gap" irridium plugs
buy the correct ones to begin with and install them
Change Plug wires...
Then see if that changes your misfire on cyl 7.....
IF not, try changing around coil packs to see if misfire follows
Proceed
