Noise
Bigjimmy
2008 Denali
After much confusion and changing pulleys/belts/water pump it seems the noise I have is transmission related.A bit of a wail on startup and it flares a bit on acceleration into 2nd gear and again a bit on downshifts but is silent when she warms up.Still drives perfectly.
I am in Scotland and a 6.2 Denali is like a unicorn over here so forget rebuilding the trans it’ll cost way more than it’s worth even if I could find somebod.
Shes also got rust issues that will condemn her in a year or 2 so can anyone recommend a transmission fluid additive to nurse her on for a little while longer?
Geotrash
Dave
Richmond, VA
2008 Denali
The 6L80 is, as far as I know, a licensed build of a ZF design, so quite similar to the transmissions used in many luxury rear-drive European cars. A good local transmission shop should still be able to rebuild it for you if it fails. These trucks still have agrarian roots in their design, which is one of the reasons they're so loved in middle America; almost anyone can wrench on them because they're a relatively uncomplicated design.
All of that said though, it may not be worth it due to the rust, of course. The only transmission additive I've seen much good written about, is LubeGard:
Bigjimmy
Bigjimmy
Thank you for trying to help,problem is I live in a small country where over 80% of cars are still stick shifts as you guys would say.
There is just no need or demand for auto trans mechanics here.
Ive had a place in England recommended to me but it’s 350 miles away and won’t be cheap
OR VietVet
Multnomah Falls
Military
Willamette Valley
Find a manual transmission large GM SUV and drive off in to the sunset.
KeyMoSteel
