noise when turning
GusSanchez300
Miami FL
So after the drop the truck is perfect but for one issue that I can't pin point.
So it goes like this, it feels as is something is shifting from one side to the other according to its position. what i mean is that I think something has play enough to make a thump noise, so if I turn right and I already heard the thump, I won't hear it again until I turn left, and it has to be a turn where the truck has some roll body and it seems as if when the rear unloads some weight or hit a bump.
I'm not sure if is the swaybar or maybe the panhard bar, which I'm leaning more towards that. has anyone had a similar issue?
Any ideas on how to fix this or opinions are welcome
dbbd1
What kind of drop did get done? Could be a spring not seated correctly.
GusSanchez300
GusSanchez300
Miami FL
3/6 drop but the springs are just sitting there with no base so it can't be that
GusSanchez300
GusSanchez300
Miami FL
I did the drop, no isolator in order to get it lower more. There is no noise what so ever with the exception of this issue.
justjacks07
