No sound from speakers BOSE
Sandaman
U.A.E.
The radio turns on with no sound. Then I replaced the stereo and amp with used ones, worked for a bit but no bass after 1 day of use. Then 1 day I left the battery unplugged and now its back to no sound. I want to get an android screen but I'm scared if audio will still not come.
I don't have an answer for you but you might want to consider adding your current 2006 SUV to your signature.
check the amp wire harness, that and the amps are known to have internal problems, sometimes smacking them will make them work again at least temporarily
Check in the underhood fusebox for the amp fuse and confirm that it's good, and that the socket and pin fitment is firm.
Trackman
