New-to-me 5.3 oil burner...
Danny3737
You sure it's smoke and not steam? Engines and exhaust pipes get water inside them from the moisture in the air condensing when they cool off and sit overnight. The condensation is heated to steam and blown out the exhaust during warm-up. Actually, when it's first started, you'll have sooty water dripping out of the tailpipe.
Agree. White smoke is water getting into the combustion chamber by either bad head gaskets or a cracked head. Those don't get better on their own
Yeah, if it constantly puffs white, then you have a problem! A little steam (smoke means there's a fire and something is burning) at startup then goes away is normal. Of course, if it actually is smoke and it has a slightly blue tint to it, then it's burnt oil and likely from leaking valve seals.
ACM
ACM
Denver, CO
It's hard to tell - especially as the weather is getting colder here in Colorado - whether it's moisture/steam, or smoke. It definitely does have a bit of a sweet smell to it.
Sent from my XT1650 using Tapatalk
Smoke slowly dissipates and can build up if in an enclosed area such as a garage. Steam quickly dissipates and vanishes. If you park in a garage and wanna know for sure if it's smoke or steam, leave the garage closed and run the car for a minute or two. If it gets smoky in appearance with a burnt oil smell, then it's smoke from burnt oil and likely just worn valve seals. If it just smells like regular exhaust but isn't smoky in appearance, then it's steam and could just be normal condensation burning off.
Sweet smell is coolant burning. Do you have to add coolant periodically? You may have a blown head gasket or cracked head. It may not be bad enough yet to show coolant in the oil or oil in the coolant, but it still needs to be monitored and diagnosed.
Laurents10
