Mystery Losing Coolant
MT Driver
I am losing about a quart of coolant from my 2009 Chevy Tahoe every few weeks. I have 251,000 miles but the engine and mechanicals have been well maintained and in good shape. Changed the water pump and all hoses last year and recently replaced the overflow reservoir on the advice from this forum to no avail. My oil and trans fluids are clear so no sign of coolant leaking into these. I have no visible leaks on the driveway or garage. I just cannot understand where the coolant is going?? I have about given up and was going to pour in a bottle of Bar engine block sealant but really dont want to do so unless totally necessary.
Does anyone have any other suggestions of where to look??
89Suburban
Bull in the china shop
SE PA
The side tanks could be weeping on the radiator. Not enough to notice dripping on the ground. But just enough to burn off once it heats up and gets under pressure. I would take a good look at those areas with a good flashlight to look for any wetness. May even be a small puddle on the support that doesn't reach the ground. Mine was doing that. I put a new radiator in and it's been fine since.
Multnomah Falls
With a slow enough seepage and when the wet coolant hits a hot surface, like say on the radiator, it evaporates before hits ground. Then as cools off, the pressure decreases and the leak stops itself.
petethepug
Michael
SoCal
What he said. Our 08 Denali had a cracked expansion tank and cracked plastic end tank on the radiator. The coolant literally vaporized as it escaped leaving what looks like a little soap residue.
The truth revealed itself on a 100* day, parked idling, front & rear a/c at max cool. The temp & pressure went up high enough to allow the steam to be visible coming out of the cracks. When refilling the truck at home when cooled off, no cracks, just residue showing.
Fix it ASAP. A low coolant issue can destroy a motor by having to run it unnecessarily for getting out of high speed traffic or an unsafe situation. If you turn off the motor or it dies while moving you lose power brakes & power steering so you’re riding a 3T unstoppable mass. Running a motor past overheating is sometimes better than running a red light.
Just Fishing
Can't fix stupid
Utah
I had that before my heater core plastic connectors blew at the T's
I had already replaced the T's, but the one line I didn't touch because it looked perfect.
No sign it was from that, I couldn't see any sign of leakage, just the dex cool smell.
When the lines blew my temp gauge pinned.
On a brand new engine... :banghead:
as others stated and I have experienced myself a slow leak will dry off from the wind and not leave a drop, it will however generally leave a "redish-orange" tint
somewhere....... you will need a flashlight and mirror and start by looking up from underneath the vehicle, you might have to pull the the fans off to look at the backside of the radiator clearly. this includes under the waterpump, around the steam vents on the heads, heater hose T's etc, etc,
also remove any splashguard or skid plates so you can get a better view.
once had a leak out of a hose once that only spit a little toothpick sized leak under pressure-sometimes
Flem2009
