My tip for plug #8
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
i was able to get to plug 8 easily with a 3/8 ratchet, 5/8 plug socket and cheater bar. No swivels needed. It's easier to remove the bracket for the trans dip. I Pb blasted the bolt holding it (15 mm). Once removed. I zipped tied the tube out of the way. Now I was able to fit a ratchet and plug socket perfectly with plenty of space to swing a cheater bar. Also recommend using Pb blasting the plug. Last thing you'd want to do is. Trying to heilicoil repair in that spot. Hope that helps
Erik G
Houstone Town
get the smallest extension and you dont even need to move the tube. I had no problems whatsoever but I used different combinations of ratchets and extensions on each plub, and the magnetic plug socket from autozone. Evetybody here had me worried for nothing
...Evetybody here had me worried for nothing
Word. Sometimes you just gotta turn the interwebz off and figure it out for yourself. I read that removing the headlight required some sort of excruciating front end disassembly, but the headlight can be wrangled out without doing so if you put down a couple layers of masking tape to protect the bumper. I followed this and was slow and careful and used flat plastic pry tools, but there's a couple of tabs on the bottom of the light that sliced through the tape and nicked the bumper. I found that this could've been avoided and the whole process would've gone quicker and easier had I just removed 4 or 5 screws and a couple of plastic rivets to move that side of the bumper a couple inches and out of harm's way.
02Lightning
I went through the fender well with an extension and a swivel, after I got the fender liner loose. I had more trouble getting the wire back on the plug than anything.
#1taho
5150TAHO
niagara falls ont
Regular ratchet 1" extension and spark plug socket. Taking the spark plug wire off that's another ball game. Takes the skin off your knuckles every time!
Exactly, SK makes a 1" extension that's advertised as 1 1/2". Works perfect along with a plug socket and regular ratchet. I just did all my plugs in about 1/2 hour.
TheAutumnWind
This is what I did, and I suppose its why I couldn't understand how everyone seemed to have so much issue with this plug.
Maybe after doing countless Fbody spark plug changes this seemed relatively straight forward lol
sumo
sumo
rhode island
Turns out I don't even need to do it the way I mentioned. I just lay on top of the radiator support and just use a ratchet and spark plug socket.
Erik G
Houstone Town
I'm not super tall, 5'10. I have a 4 inch high density foam step, about 30x30. It was the bottom of the shipping box of a big AC unit. I hate getting rid of stuff like that. Perfect big safe step stool and if I threw it away it would never ever decompose...
Just saying because yes, part of it is the angle you are working at, and part of it is the tools. The last part is your ingenuity and gettin it done...
sumo
sumo
rhode island
I find it works better if you yell at it or call it dirty names like come on you *****. Well that's how it goes in my shop anyways
MTN_KDA
