electro
Hello everyone, looking for help with Pinion Bearing removal and install.
Has anyone rebuilt there G80? Looking for some insight!
The diff is screeching periodically when backing up. Fluid level OK. The most unerving sound it is making would be the clicking or ticking. Happening only when accelerating. (bearing failure, broken dislodged rollers?)
I've yet to pull the cover off and actually have a look. Due to its continual and on going "proper" operation it would hint at just a bad bearing. When the squealing starts it sounds as if to originate from the front of the diff housing. Possibly Pinion Bearing/Seal
I'd love to have a rebuild kit ready to go and remove the diff. on a Saturday morning and overhaul it, even if I spent all weekend!! To me it beats replacing it with used or new.
Can anyone reccomend an overhaul manual?
What special tools will I require? Press? Seal drivers? etc.
Recommended rebuild kit?
I assume I need to deal with this issue ASAP as it will lead to major parts if left unattended too long! I want to get this fixed up!
Please leave your .2 cents!!
Thank-you TYF,
Ryan
Thank-you TYF,
Ryan
