Moto Metal 962 33"
da318state
Moto Metal 962 33"--2000 Yukon Denali 6" Pro Comp Lift
Hey i drive a OBS 2000 yukon Denali and I recently got a 6" Pro Comp lift installed. I guess since I've got my lift I'll change this to a build thread. Tell me what you think of my ride, updated pics of 6" lift will be up in the next couple days
Lift Specs:
6" Pro Comp Lift
es3000 shocks in the front(very good shocks with a smooth ride)
es9000 shocks in the rear
Interior:
Woodgrain Kit
Tire specs:
18x10 Moto Metal962
33" Toyo Open Country m/t
12.5 tire width
18x10" rim
Things im looking to get:
Full LED interior for all bulbs
Grille guard
Roof Rack
Spare 33" Tire
Performance Upgrades
Re-do front tint
Modify exhaust
*****UPDATE*****12/23/13
Haven't been on here in a while but, I just finished having a 6" Pro Comp lift installed on the 00 Yukon Denali and she looks damn good! I'll post pics after I wash her up, because she's been sitting in the shop for 2 weeks so the truck is pretty dirty and dusty. Also if anyone else is looking to lift the same model truck that I have just let me know, because I know there's a lot of questions when it comes to lifting this OBS model gmc.
AFTER INSTALL OF Pro Comp 6" LIFT
AFTER THE INSTALL OF LEVELING KIT(sitting at 40" from ground to top of fender):
BEFORE THE INSTALL:
Here's a link to the tires
http://www.ebay.com/itm/151044526001?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Matt06Yukon
Wow, offroad tires on the Denali huh? Ya those might be tough to fit, you'll probably need to max out the torsion bars. I would expect to have to do more. 285's on factory wheels work decently well, 33's on aftermarkets might be tough in front. You might end up catching the inner fender well.
D
da318state
Thanks for the input! Yea its time to make the Denali look tough lol, because I'm tired of seeing Denali on big chrome 20's. So do you think with the 1.5" spacer in the back ill be fine in fitting them in the rear? But for the front do you think i can max out the T-bars and trim the fender and be ok?
Gzes
the drifting 2dr
Wichita tx
You might be able to fit them. Glad someone doesn't want to put ugly ass big rims on a vehicle that was never meant to have them
D
da318state
Gzes= you think I'll be able to fit them by just cranking the tbars? You don't think I'll have to do any trimming?
Donnie Yukonie
Yates Caretaker
Im going to guess your going to have to trim with that offset of 12.5
Gzes
the drifting 2dr
Wichita tx
It's possible. I don't know too muh about off set but have seen people do 3 inch lift and tuck 35s with trimming. Try it by cranking 2in and getting the leveling kit or just blocks on the rear. If you don't like then think about a suspension lift. You can always do a body lift but many people hate on them without actually owning them. I enjoy my body lift and can crank 2 more in and fit 35s I just need to get tires
andrewlee
I have the same rim and off set with nitto mud 33s. With 2 inch crank and add leaf in rear. I rub bad when turning.
note2
D
da318state
andrewlee=do your tires rub in the front and the rear of the vehicle and also do they rub on the inside or outside of the wheelwell? also how much lift do you have in the rear? can you post pics of the wheel turned and show me how much their rubbing
TU1881
