Low Beams Out
tiktok4321
I've done some research and this is not an easy problem to me, so I see.
Both the low beams in my Tahoe seems to go out at the exact same time. Others have said that they've had the same problem, and many have suggested solutions however, no one has stated that one solution in particular has worked.
I take that back. One person said the changing the light bulbs was all that was needed. The other potential solutions included: fuses, relay, a switch in the column, or the dash switch.
I've already checked my fuses, but that is it so far. I've also tested whether pulling back on the high beam pass would turn on the low beams and it doesn't. Has anyone else had this problem and successfully fixed it? My next quest will be to pull the bulbs, as much of a pain that is on this truck.
Sent from my Pixel 2 XL using Tapatalk
tiktok4321
tiktok4321
Well, never mind. The improbable was the culprit. Two bulbs out simultaneously.
Off Road Pedia
