Looking for options on where to mount a Boost gauge in my 2017 Yukon
UATahoe
Have tried to search but cant really find anything. Anybody here have a boost gauge mounted up?
UATahoe
UATahoe
Good option for the pickups but the Yukon dash is completely different.
Dave Jr
South Florida
Found a color touch screen flush mount, about 1/4 inch thick total that will fit perfectly in noted area (I believe trailer brake control would go here). Uses 0-5 volt sensor signals. I’m going to use it for boost pressure and meth tank level. I’ll post specifications tomorrow
UATahoe
UATahoe
Unfortunately I have the trailer brake controller there. That will be a nice little setup though.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
How different is the steering column on 17 vs 08? This is where I have mine mounted. The fitting on autometers website says it was for a 7-14 Silverado
UATahoe
UATahoe
It's completely different but it looks like autometer makes the same pod for the 2015+ vehicles which should all be similar. I knew I remembered somebody mounting a gauge on the column. Just couldn't remember who. Thanks for posting! I think that's going to be my plan. Go with the autometer 15009 pod. Want to run one of the boost/AFR combo gauges in it.
sumo
rhode island
The one I’m using is auto meter failsafe gauge. It has different settings so you can make the led sweep AFR, boost, o2 voltage and maybe a few others. The center display can also display the same but numerical value.
Thekenstar
