Longer sway bar end links
ccd_1606
Kentucky
Curious if someone could give me part numbers for longer sway bar end links for my 04 Tahoe. It's lifted around 3" and I've read that the longer links will help the ride some.
YukonXL04
The Riverboat
Arlington, TX
Hey Cody, Do you have longer end links up front as well? if so may we have a link to those as well haha.
YukonXL04
The Riverboat
Arlington, TX
Shawn I sure don't. Just shock extenders
Sorry, I spaced out there. I figure when you use spindles to lift the front it probably doesn't throw the sway bar too far out of whack.
Thanks for the link for the rears though.
01Konvict
Boats n Hoes
Raleigh/SML
The stock height front sway bar links would work if you get drop brackets from the frame like they use on full lift kits but made for 1-2" key lifts. I think you could make them pretty easy, they look like "C" brackets
Impalenthelen
This forum is awesome! Piecing together my lift, going to need a set of those longer end links for the rear to go with my 3in coil spacers! Thanks yall
rick3645
