Hi,
Like many of you I wanted to add HDMI to my Esky, however, I had a 2016 and I HATED having cables everywhere. I took what some folks have done with the hdmi-RCA conversion and made it clean.
I originally was going to go with an Apple TV, however, even with the latest version it relied on wifi to stream videos and the buffering and boot up was just a pain. Also, the device that is streaming it still needed to be connected, so this killed two birds at the same time.
To remove the rear panel, just lift where I circled and pull up:
This is what you get:
See the mini USB connection on the GM harness:
So, my idea was to get 90deg rca cables run them down through the pocket and out the back, then into the converter. So I needed power for the converter AND the ipod, so I went with an amazon USB hub, an mini USB adapter to standard USB, made the connection and used the hub to power the ipod, the converter and ran a cable to the USB port on the dash to retain the factory USB port as well as the card reader that I will never use.
I first went with a short rca cable and just grabbed some 90 deg bends, bad idea, the were crap and I kept losing connection, so go with a single cable.
After it was all buttoned up, I ran the Lightning extension cable up to the armrest hinge and it now sits in the glove box with only the 3 rca cables showing on the panel.
Hope this helps.
If you dont want to use apple devices, you can just use a longer HDMI cable and run it along the same path.
I used a small drill bit to get the hole started then a dremel to route out the opening to fit my cables.
Hope this helps.
