Light Titanium Plasma Tubes and Bumper Cover
K2 Kaiju
The Depths
First off, I would like to thank Felix for the idea. He put the black ones in, while these are the light titanium version. I really like them. I ended up putting a new bumper cover+spoiler on as well so its like I have an all new front end for around 6 bills. Installation is straight forward as everything was plug n play. The plasma tubes are wired to the marker lights on the side (the green pigtail) so they light up in park, when lights are on, and when you remote start (really cool). They do not run as DRLs, and you may notice I switched my DRLs to amber bulbs (an Avalanche FC thing). Took me 3 hours for the whole process - most of the time was taking the bits off the old bumper cover to the new. The clips on the top grill were a ***** to remove, but the only tools I needed for the whole job were a needle nose, a couple sockets, and a screwdriver. Here are some pics...
Before:
Face Off:
Bumper Cover:
Finished:
K2 Kaiju
K2 Kaiju
The Depths
As for the light output - we shall see. Here is the pics on my garage from about the same spot, but it was almost dark in the stock picture, while sun was out when I shot the aftermarket.
Before:
After Low:
After Low + stock fogs:
After High (both low and high beams are on):
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Looks good!
Almost like the projectors need rotated a little to get a straight line though
AppocAlexx
Darth Appocalexx
Abilene TX
second set I have seen on NNBS and I still like them. If I buy a new set it will be these fo sho!
why did you get a new bumper cover?
K2 Kaiju
K2 Kaiju
The Depths
My last one had a bunch of scratches on it that didn't show up on the pics.
Sent from my SM-G900V using Tapatalk
adventurenali92
Big Bear Lake, ca
Those headlights look fantastic! Was that retrofit? Or a whole headlight setup you bought? I have halos but now I want something setup like this!
K2 Kaiju
K2 Kaiju
The Depths
It was whole headlight assembly from ebay around 270 delivered. If you have a dark truck, I recommend the black ones Felix used. These are great with silver. Removing bumper was less of a pita than I thought it would be. I replaced all the factory bulbs with new ones (2 in each housing: drl and blinker). I will find out tonight how good they work, but they sure look good...
adventurenali92
Big Bear Lake, ca
I have a silver truck. The back of the housings on the headlights I have are black and I love the contrasting color and look it gives my front end.
bl74
