memphizhoe
- Joined
- Dec 25, 2015
- Posts
- 84
- Reaction score
- 40
A little late to the show but if you were going to lift it there are man options.
1. any 4x4 kit will work the same for a 2wd because they both are torsion sprung you just don't have to worry about the difirential on the install.
2. you can go as easily as doing spindles and keys in the front to give you 3+ inches but some rough angles depending on how hard you crank and then either z71 coils in the rear or a lift coil/spacer.
3. I am currently lifting a 2wd at the moment. I went with a 6" procomp kit because it drops the factory knuckles and I can add lift spindles down the road to get a little more lift if I want.
4. the amont of lift depends on how wide of a rim you are wanting to run. A 33 isn't hard to clear on a narrow rim but if you wanted more "stance" then you have to go up more.
All that said I do like your truck lowered. But it's all up to you. @Atomic makes a good looking kit too.
Thanks man ! I’ve been researching a lot on the coil over kit. I hoping it will work out well for me lol.
