leveling kit, 285/70/17s, airbags and wheel spacers installed
scotts_4x
thanks to all the info I found here I got my new (to me) 07 yukon looking and working like I think it should. kinda crappie pics but I bet you've seen a leveled yukon 100 times!
before
after
-scott
S
scotts_4x
I have a new question: is there a window (high-low) for the tpms? I put 45lbs in the front tires and now I get a dic message every time I stated the truck to check the front tire pressure. is it because they are over inflated according to the computer? if so how do I fix this? thanks in advance.
-scott
Blazed
Accepting Donations
You realize the door jam says 35psi
It doesn't have LT tires you're gonna wear a bald stripe right down the middle not to mention it probably rides like a bag of bricks
01Konvict
Boats n Hoes
Raleigh/SML
There is a high band but not sure of number. I run mine at 45 with no lights in dash. I know the 10 or 11 newer are different sensors. What load rating are the tires? Yukon looks good
Blazed
Accepting Donations
Pretty sure the light comes on at 48 which his tires probably reach when warm
S
scotts_4x
light comes on at anything over 40 it seems like. tires are load range D I believe (truck is at home).
-scott
Blazed
Accepting Donations
-scott
That's weird used to run my 24s at 38 or 40 never had lights
Matz83
Your Yukon looks good man! Trying to get mine sitting like that. What size and kind of lift did you use front and back??
S
scotts_4x
the wheel spacers are 1.5".
dirty but there it is. the original pic was just the front of a ccm 2.5/1 level kit. after towing with it I decided to install the rear so these 3 pics have the 1" coil spacer installed.
BrentL9900
