Is anyone running this
Wagnasty
NORCAL SS CUSTOM 00-06 4-5/5-6 CUSTOM 00-06 Tahoe Yukon Etc Lowering kit
Thought about purchasing this instead of the 3/5-6 but wasn'tsure Iif it would be to low. Still plan on towing a car trailer occasionally. Currently have 20's with unknown offset. 275/60r/20 tires. Not sure if I would have issues with rubbing on current wheel and tire combo. I ordered a set of 24x10 and getting 305/35/24 but I want to wait until spring to put the wheels on. If I can run my current wheel/tires I'd like to go ahead and throw the drop on. Any help would be appreciated.
W
Wagnasty
I hope so. I wanted to add that the vehicle is a 2003 Denali XL.
NeverSatisfied
eBay Baller
Wichita, Kansas
I don't have that exact kit but have the 6" drop coils on my 5/7 drop and highly recommend those. I don't think there is one bad review about his kits and tony is always around to help. I've also purchased the adjustable Panhard from him and its a must going this low. As far as your tire size with the 20s I know that 275/55/20s will work no problem (I run 285/45/22s which are almost the same height and width) but not sure about 275/60/20s. Your 24s should work but probably will rub quite a bit. I had 295/35/24s at one point and those worked with very very little rubbing. And a lot will also depend on your offset. Really need a +30 or more wheel when lowering.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i desinged the springs around towing this is why i did a linear spring rate. If you tow its no issue. Airlift 60742 is the helper bag part number you need and will be set to go. I would do the 3 inch front drop kit its a waste of adding spindles because the 305 35 24 will be to tall. You can do the 3/5-6 kit and then 305 35 24 will be ready to roll.
W
Wagnasty
Yeah the wheels I ordered were +30 offset. I got the U2-55s B I know a lot of people don't like them but I like them. I probably will just get the 5/6 drop kit from him and the recommended bags. I also planned on getting the adjustable Panhard bar with the kit. Thanks for the response.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
front wil hit hard this is why im saying go with the 3/5-6 kit.
W
Wagnasty
I haven't actually bought tires yet. Just seemed a lot of people were running those and some had mentioned towing with them. If I did go with the 305/35 would it just be getting into the fender liner or would I have other issues. Sorry for all the questions just want to make sure I'm not going to have any issues as this is my Dailey driver.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i would do the 305 with the 3 front drop and woudl be cool
jeffsyamaha
