TahoeInFC
Hi All,
I have a 99 Tahoe, 5.7L that is starting to give me pause lately.
Like its year namesake, 99% of the time this vehicle runs very smoothly...I use it as a daily commuter and it has been very reliable. Still gets around 16 mpg if I'm good to it, and runs very smooth.
but...
Every now and then, it just starts idling rough. Not enough to where it will stall, but feels like it's missing on a few cylinders. If I tap the accelerator, it has plenty of power and doesn't miss when I take off. It doesn't seem to matter whether under load (sitting at a standstill in drive) or sitting still in park. Also doesn't seem to have any rhyme nor rhythm to when it happens.
For example, today I drove home from work and picked up my daughter at her school on the way. All the way to the school, it behaved just fine at every stoplight. When I pulled up to the curb to wait at the school, it started to idle rough. When she got in the car, I pulled away and had to wait at a light shortly after...idled like silk...no signs of the rough idle it had at the curb just seconds before. What the...?!
I've tried to find a pattern, but haven't stumbled upon anything yet. It's probably about due for a tune-up, but a weird issue like this doesn't seem like anything a tune-up (wires, plugs, cap, rotor) would fix, as most of those items normally decay slowly or just up and quit suddenly. This is on and off.
Not throwing any OBD codes! New fuel pump and plenty of pressure (~60psi, or so). No spark pop that I can detect (like from a bad wire, etc...). Runs great when you're standing there troubleshooting (of course).
I'm starting to think of things that could be intermittent, but most of them are sort of scary, like an ECM that's slowly failing, or a wire somewhere deep in the ****** of the harness that is breaking, etc...
Anyone have this spontaneous and rarely-occurring rough idle? Other than dance around a fire and sacrifice chickens, what did you do?
I've searched around this forum, and I've found some things that are probably worth checking, like EGR, plug wires, etc... Will probably start there. Anything else that it might be?
Thanks!
but...
Thanks!
