instrument cluster illumination lead
preshus
washington,IN
im sitting here in my truck with wires every where trying to figure out
where my illumination lead wire is . . . im hooking up my iDA-X100 h u
illumination wire so it dims when my lights come on in my 96 chevy
tahoe . . . can anyone help me out . . . i found the manual to the head
unit on line but it don't tell me where my wire is on my truck just what
the wire on the stereo needs to bee hooked up to . . .
http://www.5starcaralarms.co.nz/manuals/IDA-X100.pdf . . .
click on instalation and connections scroll down some and there it
is
alc5m
i was always told not to hook up the illum wire, something about killing the battery or sometihng, on every car i've ever done i've not once hooked up the orange wire
so sorry that this doesnt answer your question, lol, but i'm just saying what i've done
preshus
preshus
washington,IN
well its kool but i gota duramax battery and as much as i forget to turn my lights
off and as much as i play with my system while its not runin im sure it would be
fine . . . thanks tho . . . my illum wire on h u is blue . . . what orange wire are
you tlkn bout
99 2dr
The Real Nor Cal !
Do you have a test light? If so, start probing wires and rolling the dimmer switch up and down until you find the one the dims the test light.
preshus
preshus
washington,IN
naw i don't have a tst light but if i was to hook it to that wire wouldn't
that only dim my stereo when i dim my gauge lights instead of diming
when i turn my lights on . . . i guess if i had a tst light tho i could hold
it on each one while turning my lights on until the tester lit up . . . right ?
Pepper1700
