HOW TO: Convert to Escalade LED Tail Lights
Diesel07
I have a question. What if I wanted to do the opposite. What if I wanted to put a Yukon harness on a escalade.. This is what I want to do.. In order to install Yukon after market lights on the escalade
Would you be interested in selling/swapping tail lights? I have a 2016 Denali.
Thanks
Justin
pako
I’m interested in your wiring harness I’m trying to swap rear tail lights from a 2007 Escalade to a 2007 avalanche pleas send me your number or email we’re i can contact you
pako
I’m tryouts no to swap 2007 Escalade rear lights to a 2007 avalanche I’m interested in the wire harness you sale can you pleas send me your info
LanceD
Abq
Since the OP isn't making or selling these any more I thought I'd throw up another option.
This only works if you have the trailer harness up by the spare tire or plugged into the back of the 7 way plug:
Buy this: CURT 56584 Custom Wiring Harness https://www.amazon.com/dp/B007EA6WQU/ref=cm_sw_r_cp_apa_i_JHO5AbWPJPPR0
Clip off the 5 pin plug and add two of these with associated pins and seals with some wire. You get a ground, reverse, brake/turn L/R and park.
https://m.delcity.net/store/GT-150--Male-Housing/p_810485.h_810490
Plug it in and go. Should cost less than $50 for everything brand new.
Only thing you would need to do is add a resistor to keep the blinkers from hyperflash.
I can assemble this for you if you don't like wiring stuff for a fee. Just thought I'd try to help whoever is still looking to do the mod.
BG1988
the swap is pointless just get some Taheo hybrid led lights
Smokin Denali
