How do you disconnect the wire going into the rear blind spot detection unit mounted to the rear bumper? 2017 yukon denali xl...
Bpm150
Hi I am wondering if some one could explain how to properly unplu the wire going into the blind spot detection unit in the rear bumper (driver side)
I see there is a red clip that slides out... However after I slide the red clip out and pull on the connector it still doesn't pull out... I do not want to pull on it too hard. I am wondering if there is anything else I need to do in order to pull the plug out. Is there something else holding it in? Do I need to put pressure in another spot or pry up in another area with a flat screw driver?
I just want to take a look at the connectors to check them for corrosion. Curious if my "service side view detection" error is something I can see an obvious issue without needing to get the codes scanned at the dealer.. ($160) diagnostic fee.
JamesLond
You got a picture?
If it looks the way I think, you might be able to use disconnect pliers on it (Lisle 37160 is a choice).
Other than that, there might be tab you need to push down on after sliding the clip out.
Off Road Pedia
