How do I know if I have......
davidsSLT
Columbus, Ohio
Autoride
and
Tire pressure sensors?
03 Yukon SLT 4X4
Reason I ask is all 4 of my tires were down to like 25 psi and I had no notification on my dash.
The constant buzzing when I get in the truck after a while, is that my air pressure from the autoride?
Sorry for the noob questions but im trying to learn about this truck as much as I can.
skbishop90
Autoride
and
03 Yukon SLT 4X4
2005 and up models should have the TPMS standard, as they were mandated by our lovely government. BUT, dont quote me on this, I think the TPMS was an option in 2003. You may not have it. A simple test, get in and turn your key to the on position(dont crank it) and your dash lights will do a self test. All the lights will light up and then turn off. The check engine light, ABS light, etc.. If you have a tire light, it is on the top right of the cluster. Right above the oil pressure gauge. It will also tell you in the digital display, tire pressure fault or something.
PwtrSS_OakCliff
Dallas, TX
If want to know if you have Autoride check your front shocks. If they have a braided line going to them then they are Autoride. If not then you don't.
Antonio
Reveita42
