How do I determine the exact model of my front differential?
Mr T
Folks:
This Saturday I'm going to have my 2008 Denali XL, that has 192K miles, up in the air to listen and look for the cause of rotating noise when it is under power. I think the front differential or transfer case is the culprit. Both front hub assemblies have been replaced in the past year and this only hums when under power.
Anyway, I was looking up the price or front diff. replacement, just to prepare the budget for IMPACT. Well, I noticed there are a few different models I could pick from. Re-manufactured, of course.
Does the door tag tell me what ratio my front and rear are at? I know they have to be the same; just want to be able to shop for the right unit. The tag has the VIN number, of course, and also Model number as K10906.
I believe it diffs have to be either the 3.73 or 4.10 RATIO.
Thoughts?
OR VietVet
Multnomah Falls
Military
Willamette Valley
If the rear axle is a 3.73 the code would be GS3 and GT5 for 4.10 gear ratio. You can match from there. It may be a different ratio so you should just google the RPO codes for your rig and see what ratio you have.
wjburken
Eastern Iowa
Folks:
Thoughts?
Look at the RPO sticker in your glove box and see what you have for G codes. My guess is you will see GU6 which is a 3.42 ratio.
M
Mr T
Trevor, your Denali has 3.42 gears. Your front axle is 8.25" and referred to as a clamshell design. AAM makes it. www.demandaam.com
You probably just need a bearing replaced, going to tackle the job yourself? There are some good write ups on here.
Swathdiver: I would rather tackle it myself. I know how to remove the diff. I had to drop it when I replaced the o-ring on the oil pump pickup tube. I don't have a press to press the bearing from the race, but have access to one. I know that would save me a LOT of cash over buying a whole new assembly--which would be a waste. I've changed the gear oil every 30K, so I'd be shocked the spline and other gears are gone. All the oil that was removed was "normal", if you will. I too think it is likely just one of the bearings going out. I would probably just replace both while in there.
I do wish I had a comprehensive list of special tools I would need. I have the usual that let me do hub replacements, break jobs, o-ring replacement, shock replacements, etc, etc.... Just worried I will need other special tools to pull bearings loose.
So I'm getting ahead of myself as I don't know for sure if that is the issue (noise) but will determine that this week end. In the mean time, I looked at the link you provided and got to this page:
http://www.demandaam.com/product-catalog/installation-parts-and-kits/master-bearing-kits
half way down is 74067005. Looks like the bearings I would likely need. Is that what you were thinking?
M
Mr T
Wow, first time I've looked at one of these. Lot's of 3 dig codes. There is a GU6 and G69 and G80. So your guess looks to be correct.
wjburken
Eastern Iowa
That sticker is the story of what your Yukon has. If you go out to www.gmc.com and click on the CHAT NOW box in the bottom right corner, they can send you the full build sheet for your vehicle if you provide the VIN number. It will list all the RPO codes for your vehicle and what they mean.
G69 is Auto Level Control - Air ride shocks in rear with Air Compressor
G80 is Locking rear differential
Both standard with the Denali package.
No! 74067004, your front differential is 8.25". In the picture of that one, I was thinking the two that are #6 or one not shown that is at the end of the fixed tube but what really do I know from over here? LOL
@Matthew Jeschke
Matt here rebuilt his a while back and did a great write up, slightly different, but good info.
M
Mr T
@Matthew Jeschke
I'll check out his write up.
On the AAM website I put in retailers who would sell that part set locally. It listed a company not too far from my home. I called them and within 2 min they had told me what I needed was the 8.25 as the 9.25 is for Dodge applications or GMC 3/4 ton and larger. They clearly knew their stuff. Apparently they rebuild transmissions and differentials on trucks for a daily business. They put me in contact with one of their line mechanics. He was a non-nonsense guy of 65. Said he had been rebuilding diffs since America build all the replacement parts :) Referenced sometime since the 70s. Anyway, he said it is something I could DIY, but there are two areas I need to be careful of (which I don't even recall). He then said my issue with my noise sounds like the bearing and not the internal gears (I would agree with him). However, he said he recommend a full rebuild and not gust bearings. Mostly because it has 192K on it. Said most don't make it that far and if he were to do bearings, we will likely have gear failure in another 10 to 20K or so and have to pull it from the car once more--and that's $150 to drop and put it back in.
I asked him for a quote and he said full rebuild--and him doing it--is $900 plus the $150 remove and remount it for a total of $1050. He did say he sees at least 2 or 3 of these a week and can do them with his eyes closed.
I'm leaning for them to do the full rebuild than me to yank it, press the bearings out and HOPE I do it right--to then have gears fail in the next year or so.
Am I crazy?
Sean669
