hid NNBS weird problem
clean454
ok so its not a tahoe/yukon but
ive been having problems with a 08' silverado i instelled Hids lows
and when i hit the unlock button only one hid comes on
and its always different sometimes the right one comes on
sometimes the left one
and.. when i start the truck i have to some times play with the headlight switch to get them both to come on... kinda weird
anyone ever have this problem...?!
thanks in advance
2drhoeon4s
sometimes the ballast will not ignite if it doesnt get the right amount of voltage.... atleast mine did that on my nnbs 07 silverado.. i had to always start the truck with the lights off and then turn them on.
Modded
That Guy
Only happens when you don't have a relay installed!
Modded
That Guy
A relay harness installed with the HIDs for power. Basically you can't just plug and play them.
C
clean454
hmm ok, ill have to check into it. im sure there is a write up somewhere.
emann_01
I have the same problem....relays are already on the way!
C
clean454
you had to order the kit? can i just make a relay harness.. i did it when i made my 4 high mod... and here did u order yours from EMANN?
marrickard76
