Help, no crank and no dome lights.
chinohart
Really hoping someone could point me in the next direction.
My 07 Yukon Denali won't start and something wierd is the dome lights won't work.
At first, I replaced starter. Wouldn't crank
Replaced ignition switch, wouldn't crank
Replaced starter relay, wouldn't crank
Then when I was removing the signal wire to the starter, I got it to crank a few times and start.
Like I had to jiggle the signal wire and my dome lights would pop on and my Yukon would start.
But now I can't get it to even do that.
So I'm sure it's my signal wire or trigger wire or what ever
I'm not sure where it runs to. I know the ignition switch but not sure what route.
B-train
Do you live in a salt state? If so, maybe check that wire for corrosion under the coating. I think you stumbled onto the right path inadvertently. I'm not sure how that system works without a schematic, but I'd start where you had intermittent success. And check the wire farther up to make sure it's not chuffed or pinched somewhere.
Multnomah Falls
Welcome to the forum from Oregon
Remove the battery cables, at the battery, check both for corrosion and make sure mount surface is clean and reattach tightly. May also have corrosion under the cables outer insulation.
Welcome to the Forum from NH.
Pics of the truck, please.
QuashawnDaDon
