it’s either your sharkfin antenna or the sunroof, if you have one. antenna is known to leak.
sunroof drains get clogged.
when does it leak, parked or driving? is the passenger side front of the truck lower when you park or is the truck level?
Parked is when it seems like it gets the most water..my driveway is flat so the only angle is where the front end sits a little lower than the rear..standard I guess you would say.. I checked the sunroof this morning and on one side of the sunroof the rubber weather seal that goes back and forth with the glass has came off the track and doesn’t move with the glass like the other side..do you think that could be the problem ..I may be totally wrong but I think it’s called a bellow??it’s either your sharkfin antenna or the sunroof, if you have one. antenna is known to leak.
